Free Training - Way Faster Wednesday Compilation
We published a lot of videos this year so you can spend more time drinking beer and less time on that structural detail connection. Enjoy this one stop spot for all your "Way Faster Wednesdays".
Share SketchUp, Rhino, and Revit models with Autodesk Viewer
Want to share models fast and easy with those that don't own BIM Software, check out the Autodesk Viewer. You can share autodesk and non-autodesk models including Rhino, SketchUp, and Microstation!
Change Case in Revit with Dynamo
In this video, we will show a simple, yet powerful way to change the text in your project to Uppercase using Dynamo for Revit.
QR Code Dyanmo Assignment
In this video, we unpack the journey of using Dynamo to automate the creation of QR codes to track our panels through design, manufacturing, and construction. Finally, we will go over the process of using automating sheet creation for printing out your QR codes to be used in the field.
Form Finding For Fabrication
In this video we highlight a project we collaborated on to optimize a building form for fabrication using Dynamo.
Rhino Inside Revit
In this video, we highlight the power of Rhino Inside Revit with Grasshopper. We will place adaptive components and floors using rhino inside with grasshopper.
Use Dynamo to Quickly Transfer Parameter Values in Revit
This video goes over how to change a parameter with a particular value to another parameter, by transferring that same value across.
Revit 2020 PDF Overlay
Auto Levels and Floor plans
EvolveLAB Construction Technologist, Jake Spasaro, shows off how to automatically generate levels and floor plans in Revit with Dynamo.
Revit, Dynamo and Enscape Synergy
Bill Allen shows you how to use Dynamo to link your Revit model to Enscape. This is a great tool for landscape and could be used for site utilities or any object that needs to follow topography like fencing or parking.
Automate Devices to Walls With Dynamo
Save time and learn how to start to automate face-based devices to walls using out of the box nodes in Dynamo 2.02
Adding Shared Parameters and Project Parameters With Dynamo
It's not a secret - Adding Shared Parameters and Project Parameters is not a fun task. Using Dynamo, you can bulk add shared parameters and project parameters from an Excel file saving tons of time! Sean Fruin walks you through it here!
Extract System Parameters to Host Model With Dynamo
Do you ever need to transfer MEP System Parameters from a linked model to your host model? EvolveLAB Design Technologist Daniel Cortes shows you how to automate this task using Dynamo.
Moving Diffusers in Revit with Dynamo
Tag By Element Offset & Alignment
Add intelligence to tag placement in any view using the latest Dynamo 2.0.2 out of the box methods.
Clash Grouping in under 60 seconds
EvolveLAB Construction Technologist, Jake Spasaro, covers grouping clashes in Navisworks in under 60 seconds for today's Way Faster Wednesday!
